RICOH 2090 ERROR
  • aburawda
    • May 2025
    [Error Code] RICOH 2090 ERROR
    I have a 2090 Lanier copy machine and show E20 error. How to fix this problem because the screen is on this holiday and thank you very much
  • davel
    • Oct 2011
    • 1083
    Re: RICOH 2090 ERROR
    Call a tech.
      • 36903
      First I would suggest that you learn the proper nomenclature for Ricoh Family Group machines. There exists a Ricoh Afico 2090. The Lanier version would LD090.
      If you are going to try to work on Production copiers/printers the next thing that you need to do is obtain service documentation.
      What were you trying to do without having a service manual in your hand when you got the E20 error?
