MPC 5502
  • copiman
    • Sep 2011
    • 861
    MPC 5502
    Need a little advice. I am working on a Ricoh 5502 that the fuser is causing CQ issue. Is this fuser able to be rebuilt? If so, how long would it take?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: MPC 5502
    -Yes
    -30 minutes or so
      • 34939
      Re: MPC 5502
      What type of CQ problem?
      • copiman
        • Sep 2011
        • 861
        Re: MPC 5502
        Originally posted by Cipher
        -Yes
        -30 minutes or so
        Thank you. I work at Ricoh a long time ago but am not up to date now. A customer of ours acquired the machine for free and asked us to fix it. Thanks again.
        • copiman
          • Sep 2011
          • 861
          Re: MPC 5502
          The tech I was with is the one that saw the issue. Looks like the hot roller or belt is bad.
          • cadillac2
            • Oct 2015
            • 42
            Re: MPC 5502
            for this model and the 4502 you can actually use the sp c830dn fuser, with minor mods.
            Usually you can pick up the entire 830dn fuser for the same price or cheaper (f. e. Ebay) than the parts needed to rebuild the one you have - and save yourself a lot of work at the same time. P/N 407098
            Just remove the board in the picture and install the one from your old fuser .
            Note: the euro (220V) model is 407099, the US (110V) is 407098
