Ricoh AF MP-C2051 High frequency noise
  • Mark Bbb
    replied
    Re: Ricoh AF MP-C2051 High frequency noise
    It is warmth related (more noise in warm environement).
    Lubricate the bushings of the ITB cleaning unit.
    Remove panels and use output check (pcu and ITB rotation,...), at that time perhaps remove pcdu's,...
    I am also trying to solve this mistery.
    This week I had an appointment with a customer, but at this moment it is rather cold here in our country, so we delayed the meeting.
    If the noise is coming from the power supply it is rather a different noise than from turning shafts in there bushings!
    Electronic noise is zooming, not beeping.
    replied
    If it is loudest near the power supply, you may have a power supply coil singing under load. I usually see this on entry level B/W.
  • cadillac2
    replied
    these models are known for making screeching sounds but they usually originate from the fuser. There is a service bulletin about it :
    Fuser Vibration.pdf
  • SwanyG
    started a topic Ricoh AF MP-C2051 High frequency noise
    This is the second MP-C2051 I've seen this on. The noise is only during the copy cycle and it seems to be coming from the lower rear of the machine. I've taken the covers off and the noise is loudest by the power supply. Has anyone seen this high pitched tone coming from a capacitor or transformer? All the threads seem to mention the PCU's and other mechanical issues. I could be way off base but this seems more electrical. Your input would be most appreciated.
