somebody have a tutorial to use filezilla
  • eccelobo
    replied
    Re: somebody have a tutorial to use filezilla
    Originally posted by eccelobo
    Just install with the default settings, bypass the firewall, add an user with password, add a folder with sharing privileges, check modify file.
    In the address book of the copier, set the ip address of the PC as server name and "" as path. In folder security, set the name of the user and pass of filezilla, and that's it!
    Enviado desde mi SM-G920V mediante Tapatalk
    I've just seen that the path was erased in my post. It's the back slash sign.
    replied
    If these haven't helped, just Google setup filezilla. Just remember it goes on the computer not MFP.
  • eccelobo
    replied
    If you're using an antivirus with firewall, add filezilla.exe and filezilla_server.exe in the white list. Good luck!
  • eccelobo
    replied
  • duplicators
    started a topic [Misc] somebody have a tutorial to use filezilla
    hello techs i need to use the filezilla to install scaner on ricoh mpc 2550 any help thanks
