Re: Maintenance schedule for C5502
maybe the earth but not you or your machine...
Maybe explain to her old previous copied paper picks up moisture and gets "soft"
or bends,creases etc etc....
ask her if she would put used engine oil in her car..
plus these days most countries recycle all paper.............let her load it in her car and
drop it off in person...........
"It is not an easy task to find competent and honest techs here" how so,plus you list yourself as a tech...
looks like finding competent help in the office too"Certain people in the office have a bad habit of loading used paper into the machine and printing on the opposite side"
i never understand an account buying a $10,000 color unit and cheaping out on paper or
aftermarket toners........."if you are going to the dance then dance"
I had some account here who i sold a used mpc3502 decide to use a thin extension to connect power
to an outlet 20 feet away.i told him no good, and 2 months later he calls me with weird sc codes..
I ask did you buy an heavy extension cord or hire electrician to put in outlet,"no"...
Waiting to see which board will go first.....Leave a comment:
One thing to remember is that most 'color' prints include black. The total black count is black only. For maintenance purposes, it is best to use the maintenance counters in the SP mode. Also follow the service manual to reset everything replaced. That way you know where you're at the next time around.Leave a comment:
Probably, that jam in the fuser, is caused by using 70 gr. in printing with great color coverage.
Use 80 gr paper of quality, and in prints with a lot of color coverage, make them from tray 2 in A4 rotated.
On that machine you should change the pieces when there is an image problem, jams, noise ... There is no reason to have as a reference the estimated life.
However, the counters in a recycled machine, usually do not indicate anything, because the pieces you have will not be of that machine, nor those copies.
Enviado desde mi Redmi 4X mediante TapatalkLeave a comment:
Thanks A LOT!
Concerning paper, any recommendations with respect to brand, etc? Before switching to this economy stuff we ran Double A Everyday. Any suggestions from the UMP line?Leave a comment:
I have listed the maintenance table below. Now, having said all that: when they say- The yield figures in the above table are based on the following conditions:
A4 (LT) long-edge feed 5% image coverage ratio Color ratio: 30% 4 print/job
They are not joking. Running below those numbers, especially a large amount of single page jobs will wear your parts significantly more. Over use won't really have as much of an effect as under use.
Now, as to the part lives? They're really more of an expected guide. Given the cost of the drums and developers in the machine it's usually a smarter bet, especially for the COLOR parts to just replace them when they fail and not before. As long as the machine is running well and the output quality is good you shouldn't be very worried about the counter of the parts themselves.
Our company policy is to generally replace the black drums around yield and the fusing sleeves the same. Color parts and ITB belts go until they die.
Part Number Description Unit Target
Yield
(Pages)Yield affected
by P/J
(see Note 3)Unique or
CommonPCDU D1442250 Drum Unit-K 1 300k Yes U (Note 1) D1442252 Drum Unit-CMY 1 150k Yes U (Note 1) D1449640 Developer-K 1 300k Yes U (Note 1) Transfer D1440622 ITB Cleaning Unit 1 300k Yes U (Note 1) D1446206D144
0621PTR UnitSeparation/Transport Assy
TRANSPORT SECT
ION:ASS'Y1 300k Yes U (Note 1) Fusing D1444081 Fusing Belt Unit (116V) 1 240k Yes U D1444082 Fusing Belt Unit (223V) 1 240k Yes U D1444057 Pressure Roller 1 300k Yes U (Note 1) Other D0896509 Waste Toner Bottle (Note 2) 1 150k No U (Note 1) TBAB2231276 Dust Filter 2 TBA300k No Yes TBACommon A4 (LT) long-edge feedNOTE 1: These items are common with AT-C3. NOTE 2: The yield figures in the above table are based on the following conditions:
Color ratio: 30%
4 print/job
NOTE 3: Product Support Guide
D143/D144
NOTE 1: These items are common with AT-C3.Part
NumberDescription Expecte
d Yield
by P/J
(see Note 4)Unique or
CommonPCDUTransfer D1446011 ITB Unit 1 600k Yes U (Note 3)
NOTE 2: The color development units and color developer are treated as EM parts, as the actual yield of these
units depends on the actual color ratio.
NOTE 3: The ITB Unit is also an EM part, as its expected yield is relatively long
NOTE 4:Leave a comment:
That volume virtually NOTHING for this machine, but the important thing is what are the total counters on the machine, because you mentioned in your other post that it was a refurbished unit. So it has a certain amount of previous history that could make a BIG difference on what it may need, and the fuser issue you described in that thread would be very unusual for a low meter machine
Certain people in the office have a bad habit of loading used paper into the machine and printing on the opposite side, which we think is what caused the problem. The paper currently in also a so/so quality 70 g/m2 economy line.
Any advice for keeping it running - from the point of view of a tech - would be appreciated.Leave a comment:
That volume virtually NOTHING for this machine, but the important thing is what are the total counters on the machine, because you mentioned in your other post that it was a refurbished unit. So it has a certain amount of previous history that could make a BIG difference on what it may need, and the fuser issue you described in that thread would be very unusual for a low meter machineLeave a comment:
I would be grateful if someone might let me know the correct maintenance schedule for an MP C5502 and maybe some general advice on getting professional maintenance done. In the last six months we've done 18,154 pages (10,484 color and 7,670 BW).
It is not an easy task to find competent and honest techs here, so we are trying to figure out what would be considered normal and use this as a general guide.
Thank you!
