PRINTING PROBLEM (MP 3055sp)
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    #16
    Re: PRINTING PROBLEM (MP 3055sp)
    Faulty Print/Scan SD card ?
    These machines do not have an SD for print/scan. It is built onto the controller board.
      • 37490
      #17
      Originally posted by Brianneoe
      5801-001 is a ALL CLEAR...If you scroll through 5801 you will find the NCS setting. I believe off the top of my head its 007. The last thing you want to do is a 001 or a 002.
      -007 is the fax function. NCS is -011. When you're not sure, look it up. Any service manual will do.
        • 37490
        #18
        Originally posted by sharpmind
        I went there with laptop and personal router and I checked the machine. I connected it with my router using network cable and my laptop was connected in wireless connection. The printer was printing with no issues.
        Were the 3055 and your laptop getting IP address by DHCP from your personal router?
        With the 3055 connected to the network, was it getting a connection LED and/or an activity LED? If not, the problem is in the network.
        • guitar9199
          • Sep 2016
          • 1100
          #19
          If you could connect via crossover and print just fine, but were unable to with the machine on the customer's network, my FIRST thought would be an IP Conflict. Disconnect the copier from the network, and THEN ping the copier's IP address to see if you get a response.
          Next suggestion is to go into the ports tab on your print driver and verify that it's using a TCP/IP port and NOT a WSD port. Those things lose communication all the time, and the only way to get it back is to reboot things. Once the port is set for a TCP/IP port, click "Configure Port" and make sure "SNMP Status" is UN-checked! I've seen that cause similar printing issues.
          You also might want to check with their IT people and ask if they're using MAC Address filtering on their network. If they are and haven't entered the 3055's MAC address...or entered it wrong, it'll never connect to the network properly.
          Good Luck.... these problems CAN cause hair loss!! ...don't ask me how I know.
          • illude2
            • 30
            #20
            I had this exact issue a few weeks ago. The machine could not be pinged on the customer network. It could be pinged and printed to via my laptop and crossover cable. They could plug a laptop into that wall jack and it would work perfect. Turns out the IT staff had switched that wall jack over to a different vlan without letting anyone know. Which is why their laptop would work on it and not the copier. If your laptop can print to it off their network the machine is 100% ok. It is their network.
            • totoro
              • 568
              #21
              You are entirely correct. I must have fat fingered 001 instead of 011. I hope no one followed that post. 001 is a very last resort. Thanks for correcting my mistake.
              Totoro
                • 23008
                #22
                That's what I was reading for. Check for a dupe. =^..^=
                  Originally posted by totoro
                  You said that if you put your router between the mfp and the customers network then it prints fine. Have you connected to the mfp directly to your laptop with a cat5 cable and tried to print? If it prints that way there is something going on with how that mfp is connecting to the customer network. Print out the network info from each machine and compare them to see if there are any differences. ie network speed, ip range... You might also clear the network info SP 5801-001 NCS can be used to reset all network settings to default and re-enter everything .
                  GLAD to see that someone START at the BASICS!
                  ALWAYS start with the obvious cause.. work back from there..most don't realize that
                  print and scan could on some models needs different IP and/or cards.
                  Totoro, you exemplify the " Keep it Simple St***D " rule ( nothing AGAINST you ). I see TOO many newbies running STRAIGHT to boards, bypassing the simple/quick remedies.( or READING the manual )
                  As A Trainer/Service Manager, I have interviewed some "techs" that cannot diagnose their way out of a WET paper bag! ( no.... if you DO NOT KNOW how to read a manual or cannot USE Google you will not make it with me ** most other things can be taught ** )
                  • sharpmind
                    • Sep 2009
                    • 478
                    #24
                    I executed SP 5801-011 NCS but still same problem...
                    To erase the doubt whether the problem is in MP 3055 machine or in the customer network, we installed another machine coming from our office...I used the same IP, subnet mask and gateway...The machine is printing with no problem.
                    Conclusion:
                    The controller of MP 3055sp has a problem..
                    • AjitN
                      • Mar 2009
                      • 287
                      #25
                      Conclusion:
                      Just curious, why it prints from your laptop without any problem?
                      Something, some setting is holding network operation / system in the controller to function properly.
                      OR typically some problem in customer's power supply (fluctuations or spikes), open earthing OR some other device's electromagnetic interference.
                      So problem can arise to new install machine also in future. You may need to check old machine thoroughly.
                      Also as mentioned above, it is SP 5801 -001 & not 011.
                      Hope this helps
                      • illude2
                        • 30
                        #26
                        Conclusion:
                        The problem still could be in the customer network if they have the mac address for that machine whitelisted to a different vlan or even blocked all together. The new machine having a different mac allowing it on the network. If you can print from your laptop the controller should be good.
                        • sharpmind
                          • Sep 2009
                          • 478
                          #27
                          If that is the case then why is it that when we delivered new machine to the customer and installed it in the same office, that new machine is printing fine.I just entered the same IP address of the old machine.
                          We pulled out the customer's machine and checked it in our office. We connected the machine to our office network and it was printing fine.
                          • guitar9199
                            • Sep 2016
                            • 1100
                            #28
                            What could be the problem?
                            As mentioned above... it COULD be an issue with IT "blocking" the MAC address of the old unit. New unit has a new hardware address so it worked.
                            ...at least that would be MY guess.
                            • sharpmind
                              • Sep 2009
                              • 478
                              #29
                              The two IT personnel of the company were with me during the troubleshooting. During hours of troubleshooting, suddenly, the machine prints. We were suprised at that time. We checked the connection using PING command and it showed TLL=255 but after several seconds, it showed THE DESTINATION HOST IS UNREACHABLE. That problem continued until we decided to pull out the machine.
                              • illude2
                                • 30
                                #30
                                The mac address is blocked on the customers network or on the wrong lan.
