Ricoh SP 4310/ Error SC 899
  • cucuklotz
    • Mar 2007
    • 611
    Hi
    When I searched code online I saw that it could be network related on many Ricohs,But did not see anything specifically on the 4310.
    Has anyone had to deal with this error on the SP4310 series machines? Thanks for any help you can offer.
    Andy
  • sandmanmac
    • 3965
    Re: Ricoh SP 4310/ Error SC 899
    Common error on many, many machines. F/W updates were put out to improve performance.
    In your case as it relates to the SP4310:
    SC 899 Malfunctioning software update system fw to 1.04 or higher & PCL fw to 103 or higher
    • cucuklotz
      • Mar 2007
      • 611
      THANK YOU SANDMANMAC
      I spoke to the customer after I saw your reply,I know their computer guy so I
      passed your response to him.
      Thank you for real speedy reply.
      ANDY
        • 36894
        SC 899 in printing is usually a print job that has something that the printer is unable to interpret, often a web page that uses a strange font. If updating firmware does not correct the problem, try isolating to the computer and job causing the problem then try doing print preview and print from the preview screen.
        • Needfirm
          • Jun 2016
          • 6
          I have the same problem while it's in idle. I always have to turn off printer everyday. Anyone got firmware update for Ricoh SP 4310?
          • copier tech
            • 8106
            We can supply this for you, drop us an email should you still need it.
            www.copierfirmware.co.uk
            Kind Regards.
            • sandmanmac
              • 3965
              I had a response for you 2 years ago, and it still applies!
              http://www.copytechnet.com/forums/ri...ht=#post520570
              • cucuklotz
                • Mar 2007
                • 611
                Hi
                You can never go wrong with firmware updates,BUT from my experience
                every time I have had this error it has been a corrupt print job on someones
                computer
                Andy
                • Needfirm
                  • Jun 2016
                  • 6
                  I don't care, you are just rude. I don't respond to that.
                  I simply ask a question
                  Since you got anger issue, you shouldn't be here. As simple as that
                  • sandmanmac
                    • 3965
                    I only get angry with fools who offer nothing to the forum,
                    and yet expect the world in return.
                    In your case, you've gone as far as including your intentions in your 'name'.
                    For 2 years you've been looking for that F/w. How's that strategy working for you?
                    • Needfirm
                      • Jun 2016
                      • 6
                      Still, you are disrespectful and shouldn't be there.
                      I can ask and have any names i want.
                      I totally forgot i came to this forum 3 years ago
                      Been dealing with error code for 3 years and now finally copier tech helped me
                      • sandmanmac
                        • 3965
                        * My reputation status tells a bit of a different story - feel free to browse through my history, and I'm not going anywhere.
                        * You forgot the 1 single post you had made? Then "you're welcome" for the reminder.
                        * I'm glad you found yourself a new bff.
                        * Most importantly: Sending me negative rep because you think I've sent it to you from "multiple accounts" is like pissing against the wind.
                        We cannot post negative rep more than once, so it seems that you've stirred up some emotions in several different people - even with your brief history. Well done
                          • 36894
                          Your name says it all. Either the only reason you are here is to pirate firmware, which is propriety intellectual property of the manufacturer, or you need Viagra.
                          • sandmanmac
                            • 3965
                            .....or you need Viagra.
                            Hahaha....
                            • Needfirm
                              • Jun 2016
                              • 6
                              Aha... very funny...
                              Of course i will never forget my first post but still free to ASK whatever i want
                              Firmware is suppossed to be free, not paid. I know lexmark give free firmware since we have some lexmark printers. We will buy once more as a replacement and throw that stupid Ricoh away
                              This forum is really meant to be rude against anyone without proper rules, and that means i can be rude too. I wish this forum gets destroyed forever. We will find someone who can destroy it
                              Goodbye yall
