pro8100 sc471-04
  • slot
    • 341
    pro8100 sc471-04
    Anyone had ongoing problems with this cod we have changed the belt and the centre hp sesor and position sensor and the bias roller and still the cod came back after a day.
    the belt seems to move forward but we cant see why we have grease the plate in the an RTB but this didn't help.
    many thanks in advance
  • monkees
    • Jan 2011
    • 40
    Re: pro8100 sc471-04
    You read Technical Bulletin for 471 - xx ?
    If you don't find him, I ll send it to you in Italian
    I lubricate the closing movement transfert
    • slot
      • 341
      please send over just incase i havent got it many thanks again
      • monkees
        • Jan 2011
        • 40
        Google translate
        Good job
        • heicovs@gmail.com
          • Nov 2014
          • 3
          Hi Slot
          Did you ever manage to solve this problem?
          I've been struggling for 2 days now and tried numerous bulletins but no luck so far.
            • 37490
            Extracted from the US version of the bulletin:
            [B] to ensure it stops flush against the Leveling Shoe [A] completely without an
            air gap. If an air gap exists the Leveling Shoe may move.
            • imaginemoko
              unTrusted Tech
              • Jan 2008
              • 289
              Have you replaced D1796078 - Roller Opposed? This can caused belt drag when it's life over due.
              fix the customer first then fix the machine... its simple and makes life more easy.
              • heicovs@gmail.com
                • Nov 2014
                • 3
                I followed the bulletin that explained the leveling of the machine, but that did not solve the problem.
                Also, I replaced the ITB belt along with the opposed roller and since then, I've been stuck with the SC 471-04
                I contacted a product specialist and they suggested I adjust the Roller that does the belt correction(the one that has a plate with adjustment lines on the side).
                That made a difference, however the code still comes back after a while.
                • heicovs@gmail.com
                  • Nov 2014
                  • 3
                  I followed the bulletin that explained how to level the machine, but that didn't solve the problem.
                  I replaced the ITB and the opposed roller and since then I've been stuck with the SC 471-04.
                  I contested a product specialist and he suggested I adjust the roller that moves the belt(the one with the plate that has the adjustment marks on the side).
                  That made a difference but the code still comes back after a while.
                  • slot
                    • 341
                    sorry guys we did fix this by cleaning all the rollers in the unit 2/3 times then it seemed to settle down
