MPW3600 ratio
  • Hadster
    • Aug 2011
    • 264
    MPW3600 ratio
    I have a MPW3600 printing perfectly except it is about 1% too big for the customer's mechanical drawings. This is only on printing NOT scanning/copying. Is there a way to adjust in SP mode or will they just have to reduce to 99%?
  • mikadonovan
    • May 2008
    • 2931
    Re: MPW3600 ratio
    In the PCL6 driver, go to the reduce/enlarge drop down menu and select "fit to print size". Register the current settings for quick access. Should be good to go.
    NEVER ASSUME ANYTHING
