color controller E-22B
  • NAZ
    • Feb 2017
    • 5
    [Electrical] color controller E-22B
    how can I do system software for the color controller E-22B??
    my color controller E-22B is not booting but I have some green light inside on the mather board.
    thanks,
    • 37513
    Re: color controller E-22B
    Which MFP do you have it attached to? NP C6502/8002 or Pro C5100S/C5110S? What exactly is the Fiery server doing: not turning on, not booting Linus OS or not loading fiery software?
    • davel
      • Oct 2011
      • 1106
      No recent experience with Fiery but you should have access to system software and read the manuals.
      • nysamara
        • Apr 2016
        • 58
        Hi! Any update on this? I had the same issue 2 days ago... then I changed the ram to the other socket and it start working. Yesterday it stop working... I replaced the ram but I still dont have any response from the Fiery. It turns on but there are numbers in the back display.
          well almost a year later... no update. This is pretty common with Non-Techs that we try to help.
          what are the 3 numbers on display?
          have you tried just to boot machine w/o firey?
          • nysamara
            • Apr 2016
            • 58
            Sorry... with no numbers. The back display is just off...
            • nysamara
              • Apr 2016
              • 58
              I configured the machine to run with the embedded controller. But I need it to run with the Fiery.
              • nysamara
                • Apr 2016
                • 58
                Hi all! I corrected the problem. It was initially working erratically and then ended just turning the lights inside and not the rear display. I was able to correct it! I observed that the mother board was full of dirt, I removed it and cleaned it using alcohol 91% with an spray. Then let it dry and after an hour finished drying it with a blower at a very low temperature. I assembled it and it start working!
                  Just a hint.. some here will tease and say you should put in microwave...PLEASE DON'T!!! But Welcome and glad to see you got it cleared... most times a fiery isn't really needed .. just a way for sales to make bigger $$$. Increase ram.. format Hdd properly. And you should be GTG. Unless you are doing REALLY high content graphics production.
                  Again congratulations!
                    This is what you said to begin with...
                    "It turns on but there are numbers in the back display."
                    Did u misstate.. or typo...?
                    • nysamara
                      • Apr 2016
                      • 58
                      It was a typo... I initially didn't had anything in the back display... it was off. Now it is normal... It is displaying "00".
