can i use a mpc5502 fuser sleeve on a mpc3502?
  • fshead
    • 2356
    hi..
    anyone try using a mpc5502 sleeve in a mpc3502?
    d144-0032 is the faster unit sleeve
  • tomcatt
    • Jul 2010
    • 91
    Re: can i use a mpc5502 fuser sleeve on a mpc3502?
    Yes. I have with no problems.
    • fshead
      • 2356
      thanks..
      I dont want to pop one in and start dealing with fuser codes..
      I see a lot of different part numbers for them.
      Is one any different or better than the other?
      Or are they all the same?
      thanks
      • davel
        • Oct 2011
        • 1085
        Higher wattage lamps in 5502
        • fshead
          • 2356
          i would think higher is better...
          I can see not using a mpc3002 on a mpc5502............
            • 36986
            Originally posted by fshead
            thanks..
            thanks
            Just be sure to order one for your global market. 220v lamps do not get hot enough on 125v. 125v lamps burn out on 220v.
            • fshead
              • 2356
              i have to look at my mpc3502 fuser cores i saved to see if they show voltage..
              I would assume EU part number would be different than NA.
              • keithxxiii
                Just a tech
                • Nov 2014
                • 468
                Yep they really are different. Here's the part numbers for 3502 sleeves.
                NA: D1424272
                EU: D1424273
                CN: D1424046
                Aye! Cut the crap
                • fshead
                  • 2356
                  THANKS
                  i usually will look at precision rollers online catalog and compare..
                  some numbers they show are " D1444272", D144-4032, D1444081,D1444045
                  I didnt know if there was a modified mpc5502 fuser sleeve like they did with the mpc3502 sleeve..
                  There is a lot of old "new"parts kicking around on the internet..
                  • Athlontini
                    • Jun 2012
                    • 269
                    I used to get fuser codes when I (accidentally) used to put 5502 sleeves in a 3002/3502. They were really intermittent, but they were there. On the other hand, I've run across machines where another tech did this same thing, and they were working fine.
                    Short answer: You COULD, but not worth the risk/headache if you get call backs.
                    • HitMan
                      • Aug 2015
                      • 170
                      If you're using genuine parts they changed the belt to work accros all of the different 02 models bear in mind of the different part numbers for different regions. This bulletin does warn on how sc codes can appear
                      • fshead
                        • 2356
                        i dont unwrap the paper wrapper till unit is installed..
                        You know the do not touch the service as it might code out sounds very weak to me..
                        I ended up not trying the 5502 on a 3002 as fuser codes could make my life hell...
                        • HitMan
                          • Aug 2015
                          • 170
                          The belt can warp in the centre very easily at the slightest bit of pressure. I my self have mishandled a belt unit and caused these errors
                          Sent from my SM-G930F using Tapatalk
                          • fshead
                            • 2356
                            I ve had them Crinkle in the middle but when i took it apart the cotton lube felt was destroyed in the middle...
                            • anothertech
                              • 1757
                              Where do you get the idea that they changed the belt to work accross all of the different 02 models?
