Google Print MP C305SPF, FW update ?
    • 37490
    Re: Google Print MP C305SPF, FW update ?
    Originally posted by Fremalea
    can I partition the SD card? can it work? Because I do not have a small SD card.
    You need to use a software such as MiniTool Partition Wizard. The card size might not be the problem. SD cards formatted by the Windows format utility do not always play nicely with firmware updates. Ricoh has for years recommended using the Panasonic Memory Cards Format Software. SD/SDHC/SDXC Memory Card Download | SD Memory Card | Digital AV | Support | Panasonic Global
    • Fremalea
      • Jun 2019
      • 42
      Thanks slimslob I'll try.
      • Fremalea
        • Jun 2019
        • 42
        So i tried everything : another SD card, resize SD, format properly, create folders : romdata -> D177 -> files
        nothing works, always error : SC868-00
        i would like to flash by web interface, but i only have .fwu
        Is the MP C305 compatible SDHC?
          • 37490
          #19
          SC868-00 would be a device error not a card error. Are you sure you have the SD card in the correct SD slot?
            • 8144
            #20
            Poster is using a 16GB SDHC card these weren't available when the MP C305 was released hence the SC868 error!
            • Fremalea
              • Jun 2019
              • 42
              #21
              Yes, I'm sure. Bottom slot
                • 37490
                #22
                For a device error:
                1. Turn off the main power switch and check if the contact with the SD
                card slot and SD card is normal.
                2. If the contact is normal, insert the SD card into the slot and turn on
                the main power switch to check if the error occurs again.
                3. If the error occurs again, replace the SD card with an SD card for
                another user, and turn on the main power switch.
                4. If the error occurs again and again, replace the controller board.
                Looks like your down to step 4. Either that or see if you can get the remote firmware and use WIM.
                • davel
                  • Oct 2011
                  • 1104
                  #23
                  [ATTACH=CONFIG]42767[/ATTACH]
                  .fwu files should be in romdata folder, no need ford177
                    • 37490
                    #24
                    Incorrect
                      • 37490
                      #25
                      To my knowledge NO as far as firmware updates.
                      • mincopier
                        • Dec 2015
                        • 289
                        #26
                        Not sure if it was mentioned but does the code come up when the SD card is not installed?
                        The Google Cloud print Connector for Ricoh is sold by the local Ricoh dealer. It is not a free app.
                        Set up using Google Cloud Print Classic. This allows printers that are not Cloud Print ready to be used with the Google Cloud Print service. Basically a local windows computer acts as a "server" for the Google Cloud Print service. This is free.
                        • iscott
                          • Mar 2010
                          • 344
                          #27
                          In the event that the 305 is not Google Print Compatible, Try downloading one of the Ricoh print apps from the Play store. Ricoh connecter app is the newest (I think).
                          • Fremalea
                            • Jun 2019
                            • 42
                            #28
                            All is fine when sd card is not installed.
                              • 8144
                              #29
                              Use a standard SD card MAX size 2GB to be sure with the .rfu files in a folder called romdata (nothing else on the card)
                              • Fremalea
                                • Jun 2019
                                • 42
                                #30
                                i only have .fwu
                                copier tech, you would not have .rfu files to do it from the web interface?
