SP4100 tray prob
  • The_man
    • Jan 2016
    • 40
    SP4100 tray prob
    Anyone had this on this old bugger!!! OK so when device ready pull tray out still says ready and it will try to print job. Have been into SP mode tried all paperfeed sensors all check out ok swapped a few around no joy all connections on board off/on ctrl out/in even nram off/on. With sensors disconnected same fault.....doin ma heed in.......obvs when device runs out of paper calls jam instead of tray empty message.
    • 37490
    Re: SP4100 tray prob
    Normally a problem with the switch that detects the presence of the tray.
    • The_man
      • Jan 2016
      • 40
      Ok no tray detection on this just size switches, anyway turned out to be bypass sensor flag just not sitting inside sensor this caused a short feed from the bypass roller and with no paper in bypass calls a jam, cannot see bypass roller from above device so put me off the track.
        • 37490
        If it is Ricoh's standard 4 section size switch, one of those sections is the tray detection switch. I have replaced more of them for that section being bad than wrong size.
        • The_man
          • Jan 2016
          • 40
          Cheers slimslob,, in this case it has 3 actuators or size detect sensors but not faulty in this situation thanks will log that though.
