Spc431 fuser
  • CableGuy
    Impulse Drive Engineer
    • Oct 2008
    • 417
    Spc431 fuser
    Hi All
    Does anyone know if a SPc431 fuser unit would work in a MPc300?
    We're having an error of SC555. Thermistors have been replaced.
    The price of the copier replacement unit is silly
    Many Thanks
    • 37490
    Re: Spc431 fuser
    The first thing I would do when replacing the thermistors does not correct a fusing error is to check the thermostats.
    • sandmanmac
      • 3981
      Re: Spc431 fuser
      Originally posted by CableGuy
      Hi All
      Many Thanks
      I saved this from a thread from several years ago and have done it a couple of times myself ( I wish I could give credit where the credit is due):
      Fusing Unit: Two things are required:
      • Change the side cover (one has ‘ribs’ the other is plain)
      • Remove the large cover over the fuser connector. Unscrew the connector to free the harness and turn it over. The 9 pin connector on the printer version has 2 shorting loops, but on the mpc300 has 3 loops. Swap the connectors and away you go!
      • skinnyb
        • Jul 2008
        • 291
        Re: Spc431 fuser
        This. I do it all the time when I have to have a whole Fuser. Typically rebuild them but sometimes it's necessary to replace..
        Sent from my LM-V405 using Tapatalk
        • fshead
          • 2376
          Re: Spc431 fuser
          Hi All
          Many Thanks
          yes
          i do it all the time.............
          swap connector with 3 jumpers and plastic guide on the side...
          I tried to gut a few connector to make jumpers but they are very small pins...
          I have a bulk of spc430/c431/c440 [parts and they save me $$$$$
          • fshead
            • 2376
            Re: Spc431 fuser
            SRRY DIDNT see SANDYS REPLY............
