disabling Paper Cut
  • vigour
    • Aug 2010
    • 1038
    disabling Paper Cut
    Someone gave me an Aficio MP C400SR that had Paper Cut installed.
    How can I disable this.
    I am a retired Canon tech
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Re: disabling Paper Cut
    If you can browse the device from WIM, uninstall the app from extended feature settings. Set the Function Priority to Home/Copier.
    If not then restart the device. While loading the Java TM, press the user tools button then select extended feature settings and uninstall the embedded.
    Aye! Cut the crap
    • vigour
      • Aug 2010
      • 1038
      Thanks I will try that
      • vigour
        • Aug 2010
        • 1038
        After uninstalling the extended applications I got a message....
        Top use the following functions Set Key card.
        Document server
        What else do I need to do.
        Is there a factory reset function
          • 37489
          Something is not set right somewhere in User Tools - System Settings - Administrative Tools
          • keithxxiii
            Just a tech
            • Nov 2014
            • 469
            System Settings - Administrator Tools - Enhanced External Charge Unit Management - Remove all selections (Copier, Print, Scan, ETC)
            Aye! Cut the crap
            • CopyBats
              • Aug 2011
              • 146
              Also doesn't hurt to make sure this is also off.
              SP Mode\System SP\5112\(Default Opitonal Counter Type) 0: None
              If it works, don't touch it.
                • 37489
                What really helps is to have the installation instructions for Paper Cut and reverse all changes made to install.
                • illude2
                  • Mar 2016
                  • 30
                  5-113-02 Set to 0 to disable that message after the app has been uninstalled.
                  • mincopier
                    • Dec 2015
                    • 289
                    Had to do the following on a Ricoh machine recently after improperly disabling PaperCut. In my case we were getting a SC637-1 code.
                    Check User Tools > System Settings:
                    1. User Authentication Management > set to "OFF"
                    2. Machine action when limit is reached > set to "Allow Continue Use"
                    3. Enhanced Print Volume Use Limitation > Tracking Permission & Stop Printing > set to "OFF"
                    4. Auto Delete User in Address Book > set to "OFF"
                    5. SP-5-401-230 > set to Initial (00H)
                    • vigour
                      • Aug 2010
                      • 1038
                      This worked for me bro.
                      Thanks a lot
                      Thanks to all who posted
                      • pow3r77
                        • Dec 2023
                        • 4
                        Thank you man!! You save my brain!!
