Sc621_00 + jam j001
  • Printerrest
    • Jan 2020
    • 2
    Sc621_00 + jam j001
    Hi everyone,
    I have a problem with Ricoh pro 8100s jam code J001 and some time SC 621 00, there was a problem in AC drive I replace it
    I check all the sensor, ac drive all it work
    Also it give toner cartridge door open itest the door switch it didn't work
    Would you help me, thanks in advance
  • GIUBOSS
    • 1435
    Re: Sc621_00 + jam j001
    are you now stuck on the toner door open? are you a technician? does the jam occur from all paper trays?
      • 37489
      +1 on that
      Also, are you trained other than key operator training? Do you have a service manual in your possession?
      If you were trained and had a service manual you would know what SC621 and J001 were.
      You should not be working on Production level equipment without having been trained.
