SPC 830 DRUM/DEV UNIT
  • fshead
    • 2376
    HI
    I know this might be discussed before but I dont remember the answer.
    If I want to use a mpc3002 drum unit on the SPC830DN PRINTER is it just the drum face cover
    or do i have to swap out the TD sensor too..
    I use to have a shop SPC830 but sold it and I dont see too many of these.
    thanks
  • GIUBOSS
    • 1435
    Re: SPC 830 DRUM/DEV UNIT
    if I remember correctly, just cut a piece of the part where there is a metal inside the RJ45 to insert it
    • fshead
      • 2376
      thanks but i thought that cutting the corner was for swapping K DRUM FOR COLOR
        • 37489
        Attached is the cheat sheet for modifications needed to use certain PCUs in others models. The modifications might also apply to the SPC 830.
        B2C_Drum_Cheat_Sheet_v2[1].pdf
        • fshead
          • 2376
          I know I had a full set,low meter SPC830 I pulled but danm if i can find them.............
          • copier tech
            • 8144
            Originally posted by fshead
            HI
            thanks
            The SPC PCU are a lot cheaper than the MPC!?
            • davel
              • Oct 2011
              • 1104
              But he does not want to fit a new part.
              • fshead
                • 2376
                Thanks I can buy from a dealer I use for parts local BUT they kill me on these bigger parts and I refuse to becomes partners with them on
                what I can charge a customer...I can either rebuild some drum units with new fuji drums,drum blade,lub bar and pcr roller and cleaning roller and
                pcr cleaning rollers.
                I have a bunch of working pulls but dont really have a lot of free time...
                BTW are these even easily available by RICOH?
