Ricoh M2700
  • babu
    • Apr 2018
    • 19
    Ricoh M2700
    Hi guys I have a ricoh M2700 fully brand new imported from china the machine do not work Legal size(8.5 x 14)properly . when the press start key for legal size paper from tray, the scanner lamp scan not over A4 (R) margin. I also paper size set but do not work.
    Re: Ricoh M2700
    could be due to the region the machine is set for.. please print SMB report.. upload a PDF version on the pages here.
    was it pre initialized before you got it?
    who set it up there?
    when you say " I also paper size set but do not work "
    does is not copy?
    does it error out ?
    what EXACTLY does it "not do"
    are you a trained ricoh tech?
    • FrohnB
      • Jul 2017
      • 1919
      Re: Ricoh M2700
      I'm assuming that this machine is similar to the MP 2501??
      Like Phil says, check the region for paper size , SP 5-131-001.
      Also check SP 5-807-001, and set that to the correct area.
      EDIT: you may also look into SP 6-016 - Original size detect setting.
      Omertà
