Re: Ricoh MP C3003 sc101-01 when copying from glass
My Point to Point is old and did not show the LED connection.
Point to point shows 3 different part numbers for connections between the scanner unit and the SIO board.- D1495202
- D1495204
- D1495206
There is no D1495201 shown.
If you know the connector number that the cable was connected to on the SIO board you can find it on the point to point.Leave a comment:
Hey Bud,
get the part #
and post a request in this forum: https://www.copytechnet.com/forums/the-parts-room/
but I do think you got this one 'fingered' out!Leave a comment:
Hey Bud,
get the part #
I have had this happen before once or twice and I believe it was the ribbon cable both times. (One time had an obvious crack in it once you got a look at it).
When trying to make a copy of something on the glass, watch to see if the light cuts out perhaps when it is supposed to be on for scanning. Pretty much tells you the ribbon cable has a crack in it someplace.Leave a comment:
You can back it up in SP to a SD card or in WIM to a computer. The company I worked for taught key customer operstors how to back up in WIM and recommended that they do it any time they make changes to the address book. With most current models once backed up in WIM it can be restored to any machine. Handy when you have a customer with multiple machine and want the same address book on each.Leave a comment:
Its got same part number so should be ok. But what you could do 1st is try
Clear nvram all BUT NOT 1 & 2
format hdd
Update ALL firmwareLeave a comment:
