Ricoh Aficio SP C221 SF / 1.72 Firmware update
  • teoadams
    • Mar 2020
    • 12
    #16
    Re: Ricoh Aficio SP C221 SF / 1.72 Firmware update
    Originally posted by mga
    You could Always thy posting a thread on service manual forum someone maybe able to help good luck
    Good idea, now I will post the message there
      Originally posted by teoadams
      I'm not expert in this firmware structure but from all the attemps I tried to do it seems to me that this unfound bootloader file could be on the machine's ROM...
      it's built into firmware
        • 37490
        #18
        1) Extracting files to c:\v1.72
        2) Downloaded from: Aficio SP C220S/C221SF Downloads | Ricoh Global
        and from: SP C220S/C221SF download page
        3.1) launched self extracting downloaded file z88959L10.exe
        4.1) launched UpdateTool.exe (with and without admin privileges)
        5.1) tried with F/W Update (NET) and printer IP address and got error message
        6.1) tried with F/W Update (USB) and printer IP address and got error message
        3.2) opened downloaded file z88959L10.exe with winrar and manually extracted to c:\v1.72
        4.2) same as 4.1
        5.2) same as 5.1
        6.2) same as 6.1
        Where you launching UpdateTool.exe? The desktop, Start - run or from file explorer? If it is not launched correctly, it may not be starting in the folder where the data files are located.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          #19
          Also ask on there if they could email or private message you the extracted FW file
          Regards Mark
          • teoadams
            • Mar 2020
            • 12
            #20
            I'm launching from file explorer
            • teoadams
              • Mar 2020
              • 12
              #21
              I've noticed that in the setting.ini file the field "BOOTFILE" is empty
                • 37490
                #22
                My final suggestion. Buy a boat and use the C221 as an anchor. Then buy a new printer.
                • davel
                  • Oct 2011
                  • 1104
                  #23
                  NUFF SAID.
                  OP has followed update procedure from Service Manual perfectly, no Ricoh box has ever used USB stick to update firmware.
                  • teoadams
                    • Mar 2020
                    • 12
                    #24
                    Do you know where can I find this procedure from Service Manual?
                    • copier tech
                      • 8144
                      #25
                      Hi, I'm trying to update firmware to v. 1.72 but I always get this message: "Can't open Bootloader file. Please check Bootloader file."
                      I have tried USB and Ethernet connection with the same result; I have tried Windows10, Seven and XP with the same result.
                      Thanks for any suggestion
                      Teo
                      First check your printer IP address 192.168.0.100 is correct & you can open up the WIM page?
                      Do you have antivirus software running?
                      if you do it could be seeing the .exe file as a virus & deleting it.
                      • davel
                        • Oct 2011
                        • 1104
                        #26
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          #27
                          As I advised request on service manual forum
                          Regards Mark
                          • teoadams
                            • Mar 2020
                            • 12
                            #28
                            I'll follow your suggestion but at the moment I'm not yet allowed to post in service manual section
