Stapling not aligned Sr5000, Pro1107
  • Codex
    • May 2008
    • 704
    Hello
    I hope you are al healthy
    I'm driving crazy with a finisher Sr5000 on a Pro1107, during jobs with stapling... The staples are not aligned long the sheet as you can see in the attached pic. I tried to lubricate the rails inside, to check everything... But nothing... The problem occurs randomly but it drives me mad... Any ideas??.
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Stapling not aligned Sr5000, Pro1107
    Has the gathering roller in the staple tray been replaced? Are one of the guides the paper drops into bent? The clincher in the stapler being worn can also cause this problem, have you tried a new head?
    Hit it.
      • 37489
      Some models use a jogger top fence assembly. Check the stopper pawl and toggle spring. You may also need to check the jogger bottom fence unit and clamp unit.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        I don't think the sr5000 has a gathering roller like the newer finishers there's a reverse roller at the bottom of the Staple stack tray inside finisher also check the big black exit belt
        Regards Mark
          • 37489
          I have checked the Pro1107 service manual and SR5000 parts catalog. The SR5000 has a top jogger assembly mounted where the gathering roller assembly would be located.
