Format Hard Disk
  • bullet102
    • Jun 2020
    • 10
    #16
    Re: Format Hard Disk
    Basically this app allows you to control the copier as if you are stood in front of it.
    So for you this allows you to take control of the copier, access service mode & format the HDD.
    However accessing service mode is not really allowed by the ‘end user’
    I'm not an end user as such, I'm a network administrator. Sorry, but copier admin is beyond my skillset, however it is something I'm required to do. Not trying to do anything illegal or untoward, just trying to wipe the drives on my devices to ensure any history is removed.
    I've sent you an email - hoping you can help.
    • bullet102
      • Jun 2020
      • 10
      #17
      I've done a bit of Googling and I've seen that I need to enter the System SP mode to gain access to the menu I need to wipe the HDD. The problem is I cannot get to this menu. I have tried:
      • REDACTED
      • also
      • REDACTED
      Neither work. Is the problem because the display is running Equitrac? If so, what's the work around?
      • copier tech
        • 8144
        #18
        • RESET (yellow button) then 107 then C for five seconds
        • also
        • RESET (yellow button) then 806182 then C for five seconds
        • bullet102
          • Jun 2020
          • 10
          #19
          Perfect - thank you!
          • anothertech
            • 1769
            #20
            Can you take down the information that you posted on getting into service mode? It's not public information.
            • bullet102
              • Jun 2020
              • 10
              #21
              Done, but it's not hard to find with a quick google search, so it's very much in the public domain.
              • zed255
                How'd ya manage that?
                • 1024
                #22
                Not the point. Ricoh doesn't even put the SP mode info in the service manuals anymore because too many people who have no business being in SP mode were mucking up machines. We don't want it further exposed. It is appreciated that you edited to remove it. Thanks.
                  +1
