Ricoh MP C5000 Printer Prints Envelopes in Wrong Orientation
    • 37490
    Re: Ricoh MP C5000 Printer Prints Envelopes in Wrong Orientation
    Originally posted by dalewb74
    what software are you printing from? are the envelope settings set correctly in the software?
    His first post said Word.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Have you tried setting the document up as envelope in word and not as plain document ie page setup
      Regards Mark
      • craigp
        • Jan 2018
        • 34
        Here is a final solution to this issue for a future reference:
        If envelopes are not printing correctly in Ricoh MP C5000
        • Use correct Driver: RICOH Aficio MP C5000 PCL 6
        • Set Paper size to Com 10 Env. in Paper Size Settings
        • Put envelope in correct orientation as shown above
        Hey guys. Looks like finally this solved the problem:
        Placed envelopes in different orientation
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          #19
          Well done thanks for letting us know
          Regards Mark
            that is LEF like you stated in your OP.. have you been trying SEF all this time? and WHY ? it called for LEF. now you have to work on the border spacing see how it prints return slightly off the edge.
            • craigp
              • Jan 2018
              • 34
              #21
              Actually with my other printers that I've used in the past I was using SEF so I figured that would be the case and part of me was fearful from something getting stuck in the copier.
              • JaysOnTheEDGE
                • 61
                #22
                I'm glad you got this sorted out, good job.
