SC 693 on Pro C751
  • eccelobo
    • 113
    SC 693 on Pro C751
    Hi!
    I have a SC693 in a Pro C751 that I recently checked. I cleaned all units and it has a broken charge unit in the yellow IU, and consecuently the drum has a peeled line. So I ordered a new charge unit and drum but my concern is that it never showed that code before. I reseted all conectors on the BCU and it let me print a counter page but nothing more. I hope that with the new drum and charge unit it gets working again, but could you give me some advice in case it doesn't?
    • 35063
    Re: SC 693 on Pro C751
    SC693 D GAVD Transmission Error (Y)
    The machine cannot communicate (data read/write) normally with the Y LDB (laser control ASIC).
    • Cycle the machine off/on
    • Replace BCU harness or BCU
    • Laser unit defective
    • eccelobo
      • 113
      Solved! It was the yellow drum indeed. I just replaced it and the code was gone.
