Re: Ricoh mpc 2800 sc672
In the middle of the Mediterranean ..... MALTA
any suggestions or test points to verify which board bicu or controller board, looked around in my country to buy used but negative feedback, just installed a dx3725 but the mpc 2800 is really good for its age , have lots of toners and parts that is why i like to get it going... any suggestions ?? thanksLeave a comment:
frankly speeking ,i think i have to get hold of some boards, strange where to start..tks for response, as i cannot even enter service mode since error is at startupLeave a comment:
Touch screen problems result in either no response or the wrong response. There is a touch screen test and adjustment section in the service manual.Leave a comment:
thanks for info, really interesting to know,a tech here suggested the touch screen is faulty, could it be ??? as no buttons are functioning,is it the initialization process that when it comes to the display section it stops ???Thanks all for your supportLeave a comment:
As for the control panel, the basic display on the LCD screen is controlled by the firmware loaded to the control panel main board. The operation of the touch screen and the buttons on the panel are controlled through communication with the controller. You press a button and that action is sent to the controller. You touch the touch screen and the X and Y coordinates of where you touched is sent to the controller. No communication with the controller, no response to what you press of touch.Leave a comment:
i am about to gut a mpc2800 now if you are looking for parts.Leave a comment:
What I am concerned is that green LED 3 on Bicu is blinking continuously , is it normal or an error indication ???Leave a comment:
its a good point about the connectors, but i have checked them individually all 11 with a watch maker magnifier, thanks though for your suggestion, its a plusLeave a comment:
LOOKS?
did you disconnect the re-connect just because something LOOKS connected doesn't mean they ARE connected properly.. you COULD have a bent pin in the connector
pull the damn harnesses and reconnectLeave a comment:
It is a protective link R294 ,the lcd display lit up replacing this component , all other cap seems ok, what is your point any suggestion .the 24v and 5v are there.
really appreciate, trying to find some boards online for a fair price.Leave a comment:
Thanks , as soon after it made an error , the sc202 was not visible as the LCD was not lit (was dark), we replaced the fuse on the board Bicu the display lcd light came on and we could read the error, replacing the mirror motor now we are getting SC 652.checked all connectors to controller all seems ok. OLD mirror motor had 2 components burnt.Leave a comment:
thank you once again, i have checked cables 3 times now all looks in place..Leave a comment:
