Ricoh mp2501 back side lines
  • charm18
    • Apr 2017
    • 5
    #16
    Re: Ricoh mp2501 back side lines
    Originally posted by senakainoki
    Hi,
    35.000 Copies has taken Mp2501 new machine, front side is perfect but back side equal line will appear 5mm.. Customer using original toner..I have change development bias also.... same problem......Any body face this problem,,,,
    need to replace parts opc drum, cleaning blade and developer...
    but if the drum and blade is ok, u just replace the developer..
      • 37490
      #17
      You might be correct if the problem were on the front of the copies but the problem is on the back of the paper. The paper transfer roller, PTR, is faster and much less expensive to replace. To prevent the problem from returning quickly, turn on Transfer Roller Cleaning. Selects whether the transfer roller is cleaned. Transfer roller cleaning is necessary only when black spots occur in the image areas of copies. This can occur when bad environmental conditions increase the toner density. The default is OFF (No).
      Set this to ‘1’ when dirty background appears on the reverse side of the first page
      of a copy job.
      [0 = No / 1 = Yes]
      The actual SP can vary by model.
      • Mark Bbb
        • Jun 2012
        • 1662
        #18
        Originally posted by Mark Bbb
        Which paper has been used in that machine?
        Very thick paper - or / and - no copy paper?
        OK, it seems i have to explain myself (again).
        Paper that has been used and that is not suitable for these copiers will affect the drum-parts to wear (very) more quickly.
        So, ask customer what kind of paper he uses. Also when he uses only 1x per month a non suitable paper, that is enough for the machine to fail!
        • Mark Bbb
          • Jun 2012
          • 1662
          #19
          AND?
