Ricoh 5100s sc204-03
  • levantin
    • Aug 2019
    • 26
    hello i also have a ricoh 5100s error sc204-03 who has fixed it please help
    • 37490
    Re: Ricoh 5100s sc204-03
    Replace the laser unit.
    • levantin
      • Aug 2019
      • 26
      on the laser unit there are 2 laser boxes, so let's see which box
        • 37490
        If you had a service manual and looked up the error code you would know that the -03 refers to the M-Y unit.
        • JaysOnTheEDGE
          • 61
          Laser comes out really easy on this machine you can have it out in 15 minutes. I have to take them out often to clean the slit glasses manually when the stick wont work. the drum shafts get in the way of a proper cleaning.
          Just follow the manual when replacing there are some SPs you have to execute regarding the mirror adjustments. Good luck
