[SOLVED] Pro 1107 + SR5000 with J102
  • ricmartinho
    • 142
    [Jamming] [SOLVED] Pro 1107 + SR5000 with J102
    Hi guys!
    Just solved this one.
    If you get J102 on SR5000 when you are NOT punching, check if the mylars inside the Punch Unit are torn.
    Hope this helps anyone.
    • 36584
    Re: [SOLVED] Pro 1107 + SR5000 with J102
    Originally posted by ricmartinho
    Hi guys!
    [ATTACH=CONFIG]47100[/ATTACH]
    I have replaced them a few times.
    • kleankopy
      • Feb 2016
      • 114
      None of my customers use hole punch so not sure if their needed but we just remove them and leave off with no issues.
      • JaysOnTheEDGE
        • 61
        This also happens on the SR5050/ SR5060 finisher on the Pro 8100,8200, C7100, and C9100 the mylars get warped and chewed up and causing jamming, just take the punch unit out and remove them have had no issues doing this yet.
        • ricmartinho
          • 142
          Originally posted by JaysOnTheEDGE
          ...take the punch unit out and remove them...
          Unless your customer uses it
          In case I ever need to do that, when you remove the punch unit, how do you fill the gap?
            • 36584
            He is not talking about removing the entire punch unit, only the Mylars. I have left them off while waiting for new Mylars to come in from Ricoh. My customers that have production models do thousands of punched copes a day.
            • ricmartinho
              • 142
              I'm assuming you don't do what I've done
                • 36584
                And if the paper curl is up?????
                • JaysOnTheEDGE
                  • 61
                  yes, sorry remove mylars and re-install the punch unit, while you have it out good time to clean and LIGHTLY lubricate the punch dies
