Ricoh mp7500 strange problem, broken polygon motor ever 100k copies
  • m_donakov
    • 213
    #31
    Re: Ricoh mp7500 strange problem, broken polygon motor ever 100k copies
    Originally posted by mga
    Where are you getting motor from are they used are they from China if new strange you not getting a error with a laser fault.
    There are adjustments you should do after replacing laser unit and or polygon motor
    I geting motors from local dealers from here that have many used machines that have been used bifore and changed for new models. I only do auto ajustment od drum, if there is anything else should i do please tell me. Thanks
      I tried to tell him about the adjustments.. he poo poo'd my comment.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        #33
        I think that may be your problem these are very old machines and polygon motors are quite fragile try a new one from ricoh
        Regards Mark
        • m_donakov
          • 213
          #34
          sorry if I offended you, I had no such opinion. I just wrote that I can not find such information in the manual
            • 37490
            #35
            When you get a new laser diode unit from Ricoh will have a label on it with information that must be entered into the machine using SP2115 (Main Scan Beam Pitch Adjustment). With a used unit that label may no longer be attached.
            • m_donakov
              • 213
              #36
              I tried with new one too. Around 100k copies and after same problem
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                #37
                Its in the section dismantle and replace
                Regards Mark
                  • 37490
                  #38
                  Try REPLACEMENTS AND ADJUSTMENTS - LASER UNIT - LASER UNIT ALIGNMENT.
                    did you input the values from the new unit? this is part of the adjustment i was talking about.
                      but according to the OP it isn't in the manual.... I thought IT guys had manuals for their job... guess not.
                      four pages of back n forth comments on this problem... wow
                        Originally posted by davel
                        Never heard of initialisation for polygon motor, are you sure you are thinking of correct brand/model.
                        ok using a term from another brand .. the adjustment is what I meant and YES it is in the manual... the polygon comes with values that must be entered into the copier.
                        initialization i believe is the term Brother or samsux uses , they also have values that must me inputted for the new laser/polygon
                          it pissed me off.. here you aren't a copier tech .. but rather an IT guy. You come to us with a problem, when given advise you tell me it isn't in the manual ( i know damn well it is )
                          you are REPLACING an item ... there is a large chapter in the manual that pertains to just disassembly/replacing parts. Did you look in there? No
                          done with you 31yrs in the industry and frankly we have more problems with know it all IT guys here.
                          • m_donakov
                            • 213
                            #43
                            But that information is for LD unit i changed polygon motor laser unit is the same
                            • GIUBOSS
                              • 1435
                              #44
                              a tip, update the system firmware, you will fix any bugs in the controller.
                                • 23008
                                #45
                                Interesting conversation. I showed up late apparently.
