My Ricoh MP4045 error code sc997. Help me, how to fix this problem ?
Ricoh MP4054 error code
Re: Ricoh MP4054 error code
SC 997 is normally an error with the currently selected application or function. If it occurs at power up it could a problem with the default function or home screen. It could be caused by a bad memory dimm, the HDD or corrupted firmware. -
Do you use any extended function? Any Java application? Try to disable java in user tools or in SP mode 5-730-001 = 0Comment
Last edited by copier tech; 02-09-2021, 09:35 PM.Let us eat, drink, and be merry, because tomorrow we may die!
โComment
the sc997 code on the technical manual of that model does not exist, I have not found it, it stops at sc995-04, which are all errors inherent to the serial number, and components, have you mounted any boards of another model?"I'll be back"Comment
SC997-00 DApplication function selection error, The application selected by the operation panel key operatedabnormally (No response, abnormal ending).Software bug (mainly the application)z Check the optional RAM, DIMM, boards required by theapplication program.z Check if the combination of downloaded programs arecorrect.โComment
Good advice from all!
I would just add that it seems to me that the ONLY ones that are actually reading the manual are the responders, and that would be my 2 cents worth of advice for the poster as a good place to have started.Comment
That is where I started. In fact I was about to ask if the original poster had a manual until I noticed that there was no SC997 in the version of the manual that I have. So I then checked Gooses Guide. Apparently anothertech has a newer version of the manual than either luca72 or I.Comment
Good call on the HDDComment
And the system/copy is D2025574G Ver.1.29 2020/12/17 (later version not included in the package)
โComment
