mp c2011sp error sc547-02
  • luca72
    replied
    Re: mp c2011sp error sc547-02
    Originally posted by senakainoki
    hi,
    I have face problem MP C2011SP SC547-02. As per the technical bulletin i have check connection in between PSU (AC) and CONTROLLER Board.
    Still the same. Please advise me anybody face same issue..... Latest firmware has been updated.
    senaka
    check well also the various door switch , that can generate "zero cross signal"
    replied
    SC547-02 is a Zero cross error (relay contact fault). Check fuses on PSU. Replace the PSU.
  • francisco
    replied
    hi,
    senaka
    fuser problem
    you have to check fusing section, if damage replace,then you must reset the code,like says in manual.
  • senakainoki
    started a topic [Error Code] mp c2011sp error sc547-02
    hi,
    senaka
