Ricoh C5100pro not booting up
  • leonardcahill
    • Nov 2019
    • 23
    Upon reboot the copier will not start, the drawer is locked, found a 5 amp fuse blown. Replaced the fuse and still wont start with button. Any suggestion? No copier tech help in this remote area
    thanks in advance
    Len
  • TonerMunkeh
    Professional Moron
    • 3873
    Re: Ricoh C5100pro not booting up
    Sounds like you have had a PSU go bang. Check the ones under the bottom cover for scorch marks etc. Was the machine running okay prior to this or was this something that happened after other maintenance?
    Hit it.
    • leonardcahill
      • Nov 2019
      • 23
      Machine was in sleep mode, I came in and seen the blue light around the sleep button. Hit the main power switch and it shut down, few minutes later it would not turn back on. Found a blown 5amp fuse. Still nothing. Another odd thing is the drawer wont open, the one that locks which gives access to the fuser unit. Not sure what a PSU unit is, looking now for scorch marks. One thing is the power spiked here the other day. might or might not have something to do with it.
      l
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        l
        You have to open the draw manually it's in the manual
        Regards Mark
          • 35067
          One thing you need to do is determine what caused that 5 amp fuse to blow. FYI, PSU means Power Supply Unit.
          • leonardcahill
            • Nov 2019
            • 23
            Can you offer a power supply ( if that is it)?
            • leonardcahill
              • Nov 2019
              • 23
              We did have a power surge here Wednesday. City's electrical is sending me trouble report. My OKI been acting up as well since. Now that's fixed and the Ricoh is still down. No scorching on the PSU, still looking
                • 35067
                And if it turns out that the problem was caused by a power surge your still stuck with the cost of the repair parts. This utility company will just tell you that you should have installed protection equipment, which is true.
                • leonardcahill
                  • Nov 2019
                  • 23
                  figured as much. question is where can I get the parts to fix it?
                    • 35067
                    You need to determine what needs to be replaced first. And that is going to take some time and effort with your multi-meter.
                    • leonardcahill
                      • Nov 2019
                      • 23
                      RN I don't even know what parts availability are. Might have to replace the machine as I've a few thousand in supplies here. Know of any?
                      • TonerMunkeh
                        Professional Moron
                        • 3873
                        Find a sales location and where to buy Ricoh multifunction printers, scanners, MFPs, supplies, services and commercial and industrial print equipment
                        Hit it.
