SC 362 - No developer in the all development units (IMC 2500)
  • sharpmind
    • Sep 2009
    • 478
    Guys, what is the cause when all development units has no developer inside. Is it because the life of the development unit is reached already? Have you encountered this kind of problem?
  • sandmanmac
    • 3996
    Re: SC 362 - No developer in the all development units (IMC 2500)
    While I have exactly ZERO experience with these models, allow me still to be the first to guess that No one has ever seen this before.
    I mean let's think about it this for just a second, and see if it makes any sense ......All Dev units becoming empty at the exact same time before there is ever an SC code Displayed? No chance!
    Please provide some background on what led to this, because there is no way the machine was just working perfectly fine until WHAMMO! This happens!
      • 37738
      Lightning strike or some other cause of a major line spike that took out a couple thousand dollars worth of boards
      • sharpmind
        • Sep 2009
        • 478
        Yes, you are correct. The development units are all empty. The machine is having an error SC 362-04 so we checked all the PCDU to make sure there is no other problem. To our surprise, all developments are empty. Their office is using generator. counter reading: BW-51675 ,color-190706.
          • 37738
          And I will bet that you don't have any type of power protection installed.
          • luca72
            • Oct 2017
            • 1833
            leaving aside the discourse that powering complex electronic devices such as a photocopier with a generator, is the worst thing that can be done.
            maybe the customer ignorantly emptied them (?) it happened to us
            "I'll be back"
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Sounds like to me if all are completely empty the customer has done it. As easy to remove units
              Regards Mark
              • imaginemoko
                unTrusted Tech
                • Jan 2008
                • 289
                I remember a service call for waste toner..... it's a per call customer don't want to pay the service charge so IT person dumped all of it.... next call is SC 36*. i hope not same story with this. cheers.
                fix the customer first then fix the machine... its simple and makes life more easy.
                • davel
                  • Oct 2011
                  • 1113
                  Originally posted by alabuabutuglak
                  And why do you need developers so urgently? In theory they are ment to work on both e-commerce systems and any other app dev. that you can work with as they would you at the workshop. But practically I recommend you to visit website and bookmark their contacts just like I did. In case you will need to add some marketing features or check the code of your new shop. Something like this.
                  SPAMMER
                  • MoochPage
                    • Jul 2019
                    • 58
                    The developer units don't empty and or become empty at the end of their "life" I don't know of a machine that when it is end of life you pull the unit and it is empty. I am assuming that some voltage issue caused the machine to pull the developer out of the machine. Has the machine filled more than normal waste toner containers?
                    • Keegan Chetty
                      • May 2015
                      • 113
                      We've had a client empty the dev units after the machine required the waste toner to be emptied as well, seems more common than I thought. I did however have the toners going straight through the dev units into the waste toner bottle.
                      • UNICORNico
                        • May 2018
                        • 308
                        I'm glad to read that I'm not the only one who has had clients, acting as technicians and they start cleaning with a vacuum cleaner xD hahahaha!!!!
                        "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                        • Zaxxon
                          • 607
                          Please start you post with brand, model, problem.
                          • COPIERMAN
                            • Jun 2009
                            • 562
                            i had a customer just yesterday. that poor developer powder out of cyan unit
                            • Ben Around
                              • Apr 2012
                              • 151
                              Tech: Did you keep the old toner? Customer: No we threw it out.
