2238C jamming from tray 1
  • Rick
    • Mar 2007
    • 277
    I have two of these units giving me these problems they are feeding 20 sheets or more from this tray at once. I have replaced the feed and still
    this exists . Am I missing something ?
  • sandmanmac
    • 3981
    when you say feed.....I assume you mean feed, and separation tires?
    • schooltech
      School District Tech
      • Jun 2008
      • 504
      Damn, and I thought pulling 2-3 sheets through was a pain. I don't really see that many going through at once. Yes, has everything been replaced that will affect double-feeding, like all feed, pu & sep, torque limiters, etc? I am not looking at that exact feed system now, but most Ricoh's used the DPF system, as most manufacturers do, and unless something got damaged-bent, etc., I'd look at a bad torque limiter or something.
      Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        IIRC there is a tab or lever on the paper drawer that engages the reverse roller. Make sure the lever is not cracked, bent or otherwise damaged and the reverse roller is indeed moving up into the proper position.
        • paulg
          • Jun 2007
          • 278
          Check if the gears on the feed station are ok.
          I found one where one of the teeth on the gear which drives the sep drive had lost a few teeth. This meant the sep roller would not always turn so cauing intermittent jamming. Due to the design of these machines if someone decides to clear a jam sometimes the teeth will be damaged.
          Turing on free run and engaging the clucth with tray one out sould show up any problem here.
