Missing Airprint
  • tinalt
    • Mar 2014
    • 28
    Missing Airprint
    We have a new(to us) machine in the field and we seem to be missing airprint from the network section of the configuration
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Missing Airprint
    Machine is a MPC4503, firmware is current.[ATTACH=CONFIG]49415[/ATTACH]
    It does not have its own firmware airprint is standard on that machine but best if all firmware is up to date but you also make sure certificate is advise in user tools common problem
    Regards Mark
    • tinalt
      • Mar 2014
      • 28
      Certificate is installed, the menu where you would turn airprint on/off and set its name is missing.
        • 37490
        Are you accessing from a PC through WIM or from the Control Panel through User Tools? Does the C4503 have a Normal Operation Panel or a Smart Operation Panel?
        • tinalt
          • Mar 2014
          • 28
          Normal Panel WIM access, I am not aware how to see airprint settings from the panel
            • 37490
            I had asked because there are some thing that can only be set form WIM and others that can only be set from the control panel. There even some that can only be changed from the Service Program.
              • 37490
              You might want to review the following thread. The C3003 and C4503 are the same model series. https://www.copytechnet.com/forums/r...8=#post1627205
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                I don't think you can see it do you want airprint to work just setup correctly with latest firmware
                Regards Mark
                  • 8144
                  First update the package firmware then any modules that are newer than the .pkg.
