Error cs-402-53 Ricoh Pro c5100s
  • Cachodelsur
    • Jun 2021
    • 4
    [Error Code] Error cs-402-53 Ricoh Pro c5100s
    Hello people, I have a problem with a Ricoh Pro c5100s, the machine works fine, but if I want to use it again after 25 minutes of inactivity it throws me error cs-402-53 that I do not know what it is or how to solve it, to go back to to use it I have to turn it off and on again. If anyone knows about it, I would be grateful if .
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Error cs-402-53 Ricoh Pro c5100s
    [ATTACH=CONFIG]49576[/ATTACH]
    Thats magenta development try giving service clean id sensors etc what M dev life if doesn't clear will need new M developer make sure if you need to replace make sure you setup correctly
    Regards Mark
    • Cachodelsur
      • Jun 2021
      • 4
      I'm going to see where you say, thank you very much Mark !!
        • 37489
        I take it that you are an end user and not a trained Ricoh Production Color technician. More than likely you do not even have access to a service manual. You should not be trying to repair a production color MFP.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          I take it that you are an end user and not a trained Ricoh Production Color technician. Moore than likely you do not even have access to a service manual. You should not be trying to repair a production color MFP.
          Agreed just noticed end user let's hope he reads this
          Please Call a credited ricoh Service Engineer to repair your machine.
          Regards Mark
          • davel
            • Oct 2011
            • 1104
            Punctuation please, it hurts reading that.
            OP call trained technician.
              • 37489
              Grammar cop.
                Get a grip
                • copier tech
                  • 8144
                  From the service manual this could be an environment issue. Is the printer in a hot, cold or humid office?
                  • Code: SC402-53
                  • Description:Development gamma calculation error: Insufficient data (M). The number of valid data that can be used for development gamma calculation is smaller than 2.
                  • Causes:Remedy:
                  • Cachodelsur
                    • Jun 2021
                    • 4
                    I have an official technician, I had a very similar problem where I would throw a code every 15 minutes of inactivity and when I printed all the prints would stain with a soft magenta background, the technician changed some pieces and fixed it but less than a year ago he did it and now started with this again.
                      • 37489
                      Sounds like it is time for another maintenance service. Have you checked the PM counters. PM means Preventive Maintenance. If you use after market toner PMs need to be done more frequently.
                      • Cachodelsur
                        • Jun 2021
                        • 4
                        Yes, I will also have to call the technician again to see what solution he gives me, but with all the data that everyone has given me here it helps me to comment to the technician because even though he is an official Ricoh technician to this problem he does not find a definitive solution, thank you very much slimslob.
                        • Zaxxon
                          • 608
                          Please start you post with brand, model, problem.
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            Just so you know if he is a credited ricoh Service Engineer there's no way he can't fix it as trained engineers have a great technical backup help if we need it
                            Regards Mark
