cannot log in web image monitor ricoh mp301
  • alphablaster
    • Nov 2020
    • 32
    Hello everyone ! I have a ricoh mp301 that i cannot log in the web image monitor and i cannot change anything at the interface settings although i've done 5846-46, turned 5828-91 to 1 and 5985 to 1. Any ideas ? Thank you in regard.
  • 8T2
    • Aug 2015
    • 257
    Re: cannot log in web image monitor ricoh mp301
    SP (Factory) SP5-846-046
    Sent from my WAS-LX1 using Tapatalk
      • 37305
      Is it that you cannot login or get an error when you try to access the device. If the latter, try accessing as a HTTPS:// device and not a HTTP:// device. Someone for some reason may have created a device certificate.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Is 802.11 enabled?
        โ€œI think you should treat good friends like a fine wine. Thatโ€™s why I keep mine locked up in the basement.โ€ - Tim Hawkins
        • sandmanmac
          • 3979
          so you've done 5846-046, but there's no mention of you then logging in as supervisor in order to reset the Administrator p/w, and then logging in as administrator to turn off all administrator authentication settings which are preventing you from changing any system settings
          • copier tech
            • 8132
            Try a different browser & as always make sure the fw is the latest.
            โ€‹
            • alphablaster
              • Nov 2020
              • 32
              No I cannot login, although I tried that too
              • alphablaster
                • Nov 2020
                • 32
                Originally posted by KenB
                Is 802.11 enabled?
                I'll check it out and I'll let you know ! Thank you !
                • alphablaster
                  • Nov 2020
                  • 32
                  Tried that too but nothing..
                  • Gift
                    • Mar 2011
                    • 2458
                    probably the cause here
                    • alphablaster
                      • Nov 2020
                      • 32
                      I've never done it before, could anyone help me how to enable it ?
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        You can reach the WIM interface, but log in won't work, or you even fail to reach the WIM?
                        The printing and scanning functions are both working?
                        Is it connected with a lan cable or usb?
                        Is it apple or windows installed?
                        Did you tried firefox internet explorer?
                        • alphablaster
                          • Nov 2020
                          • 32
                          I cannot even reach the WIM, printing and scanning works, it is connected with lan cable, windows installed and yes tried firefox too but I can't reach WIM either
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            are you sure you are using the right IP address?
                            Which ip address is it?
                            • alphablaster
                              • Nov 2020
                              • 32
                              192.168.1.249
                              I didn't put this ip, someone else did it and after this cause they brought it to me
