MP 9003 with constant long warmup
  • laser801
    • May 2014
    • 151
    Hello folks, Asking for some input again. As always, I appreciate any and all responses. We just put an MP9003 out in the field in good shape. We received a call, telling us that when someone goes up to the unit to make a copy, It goes thru a long warmup which is very frustrating. Obviously it's after it hasn't been used for a little bit. All the energy settings are maxed out. I never ran into this before. Could it be going into some kind of "auto shut off" ?? Or is this common on these big machines?? I looked thru all the settings, and did not see anything. Thanks in advance, Laser801
  • Dark Helmet
    • May 2009
    • 847
    Define long warmup. Thats a 90 ppm copier with a heavy fuser. Check the specs in the manual for warmup. It's been a while since i worked on 6002 but from dead cold they were a few minutes from what i remember.
    Don't let them turn off the energy save etc or max the counters. Fusers sitting cooking all day just wreck the fuser and adjacent areas. If that machine sits for long long periods and then they expect a quick copy, they have the wrong machine. That thing is not meant for 1-2 page jobs. It's meant to run.
    • laser801
      • May 2014
      • 151
      Normally, when you power up, its about 4 mins to ready. This is in a Law office and there are many attorneys that like to run up to the machine and make some quick copies. This is where their problem is with the warmup time. We replaced a 7503 which is a big unit as well but not the 20 amper. That unit did not do this. Maybe it is the wrong machine for that location.
        • 37490
        Per the Product Support Guide the warmup time for the 9003 is 300 seconds vs 20 seconds for the 6503 and 7503. Per the service manual first copy time is also 300 seconds for the 9003. Did your sales personnel not inform the customer of this before delivery?
        • laser801
          • May 2014
          • 151
          Seems like they did not. This machine should not have gone out to this location. I'm sure we'll be swapping it out very soon. Thanks for all your input, Laser
          • GIUBOSS
            • 1435
            What does it indicate in the PM consumables list??
            • laser801
              • May 2014
              • 151
              I will have to check that, Thanks
              • GIUBOSS
                • 1435
                Have you tried opening and closing the front door while waiting? I'm not saying that's the solution...
                • laser801
                  • May 2014
                  • 151
                  I did not, But they will not want to do this every time they need to make a quick copy. I think we need to get them a smaller unit. (7503) Thanks!
                    • 8144
                    This is normal for the MP 9003. Updating the firmware does help but the fuser is the 'old school' heavy hot roller. The 9003 is designed to be run a bit like a production device, not 'one off. prints.
                    • luca72
                      • Oct 2017
                      • 1778
                      if you want a fast startup...you need a machine with a heater sleeve system, like mp5054-6054, etc..etc..
                      "I'll be back"
                      • laser801
                        • May 2014
                        • 151
                        Thanks, The unit they had before this was the 7503 with no complaints. I do agree, a 6054 would be a much better fit for their environment.
                          • 8144
                          Yes, the 7503 had a thinner lightweight hot roller hence the quicker warm up.
                          • Ricoh-ono
                            • 338
                            Change System SP Mode 5305 to Zero. This should allow increased sleep mode times and offer a disable option in user tools.
                            Do what you can, with what you have, where you are. ~Theodore Roosevelt
                            • laser801
                              • May 2014
                              • 151
                              Thanks, I'll check that out. The plan is to get them another smaller unit. I'll play with this when we get it back to the office. Have a great weekend! Laser801
