im c300 - machine ok but why does it say on panel - CALL PM SERVICE?
  • Jedi Ben
    Senior Engineer
    • 79
    nothing is over life yet. get the PM call service in the drop down status bar.
    cant find a RTB on in
    its connected via usb (wonder if this causes message)?
    machine behaves fine.
    wonder if there is a SP to adjust to turn the message off?
    Any info would be great or has anyone else had it?
    THANKS
  • mikadonovan
    • May 2008
    • 2931
    Re: im c300 - machine ok but why does it say on panel - CALL PM SERVICE?
    I would expect resetting the PM counter might clear it. Log into SP mode and see if there is not a tab that says "PM COUNTER/NEW UNIT SET. If not, resets may be in System SP-7XXX. Oh, and since that indication is on, some new parts may be in order.
    NEVER ASSUME ANYTHING
      • 37397
      Check SP 5066 and SP 5067
      • Jedi Ben
        Senior Engineer
        • 79
        Cheers for that. i will go back and chuck the latest firmware on. if that doesn't resolve it. I shall try reset of the pm counter as you suggested. will update
        Ben
        • Jedi Ben
          Senior Engineer
          • 79
          1. put latest package f/w on - still call pm service
          2. done sp 7804# execute - the PM counter reset
          cleared the message
          • Mark Bbb
            • Jun 2012
            • 1662
            Is it a new machine?
            Perhaps the user counters where set to 0?
            There is a dealer in the Netherlands who does that.
            • Jedi Ben
              Senior Engineer
              • 79
              no mate, its done 29k no parts co were over life. i have ricoh tech forum as well, put the same post on there. they informed to try the latest firmware 1st. because they had a few issues with fuser life flagging up before its actual life? not sure what flagged my pm call message but the reset sp i mentioned above cleared the panel message
              ben
