This machine is very old and I am trying to keep it going. Unfortunately I do not have a lot of experience doing this and I cannot find a service manual for this machine.
I would use this forum more often but I struggle having to adjust the dimensions on the pictures I'm taking in order to be able to upload them. I have trouble using this website sometimes, but here goes.
My 2 main issues is that I keep finding lots of "spilled" toner in the area in between the toner slider assembly and the developer. I'm not sure how this keeps happening but about a year ago I ordered an entire new slider assembly. On picture #5, the area circled in yellow is where I keep finding lots of spilled toner. Forgive me for not knowing the technical terms, but the area circled in red is that little box that sits on the slider assembly, that has that little lever which opens and closes a little port where the toner gets shuffled to the developer? Initially I thought this was where the toner was spilling from, so I took this little box apart, and totally washed everything including the little spring, and then put it back together, I made sure it snapped on tight. However, the toner would keep spilling into areas it's not supposed to. I have a feeling that little lever isn't coming all the way down and this is how toner is spilling. Perhaps the issue is with the developer unit? There is a little lever on top and towards the front of the developer unit which opens automatically as you slide the developer in.
In picture #4 I circled the area in yellow where there is also lots of toner spillage.
In picture #2 you can see that the toner is even spilling over to the transfer roller.
Picture #6 shows what it looks like if I don't clean it out for a few months. This is how I initially discovered it when I was changing a toner cartridge last year.
I am at a loss. I am considering buying a new developer but original ones are $700 however I did find one for under $100 here:
this website is also where I ordered the toner slider assembly from about a year ago.
While this issue with the toner spillage did not prevent me from printing and using the machine, I would just have to vacuum out that area like once a week.
Another issue I am suddenly having is the papers are jamming as they go thru the fuser. When I open the side panel it seems that the paper is creasing towards the top left corner of the page.
I can order one of those fuser repair kits but I have no experience doing this. I am thinking of ordering this used fuser on ebay.
I'm not sure I can fix either the developer or the fuser. Perhaps I should just buy these 2 parts and hope it solves the issue.
