Mpc 2004 and Imc series drum problems
  • Codex
    • May 2008
    • 672
    Hello guys
    We have s lot of this machines on the field and i experienced a lot of quality issues due to deterioration of the charge cleaning roller that becomes sticky and ruins the drum unit... No RTB from Ricoh. Have you experienced the same problems?
    The units have from 12k (the machine made yesterday ON THE PHOTOS) to 30k....too early in my opinion. The target yield is 48k
    This gallery has 2 photos.
    Memento Audere Semper
    • 34940
    The only times I have seen cleaning rollers that looked liked that is when someone has tried to clean the charge roller improperly and gotten water on the cleaning roller.
    • Codex
      • May 2008
      • 672
      This one was new, i was the first to open it.But i saw the same issue on many MPC2004, maybe a material problem, i think Ricoh should change the material of this roller
      • copier tech
        • 7879
        This usually happens with age, even if the PCU count is low the foam can perish over time due to environmental conditions, ozone etc.
        • emiliorsg
          • Jul 2018
          • 140
          I have had the same problem with units with few copies but installed for years. It seems that the sponge breaks down over time.
          • Larhal
            • 348
            I had seen the same over here, crappy foam rollers.
            Larhal
            If all else fails read the Service Manual!
            If that fails, meet me at the pub and we will discuss it, maybe, probably not we are at the pub!
            • dalewb74
              • Feb 2018
              • 1057
              compatiables? firmware?
              • GIUBOSS
                • 1329
                I remember them being white
                • luca72
                  • Oct 2017
                  • 1511
                  we spoke with codex via whatsapp, and it seems there was a production problem, which has been corrected, it seems that in certain conditions of high humidity and high temperature (normal in Sicily) the cleaning charge roller compound "hydrolyzes" (that's what it says) and becomes sticky... this involves that specific range of machine series, then it seems it was corrected in production.
                  I attach rtb.
                  "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
                  • GIUBOSS
                    • 1329
                    This appears to be an older batch of defective drum units or cleaning rollers, which I have not had any issues with.
                    • luca72
                      • Oct 2017
                      • 1511
                      yes, in fact, not even me here in Milano, even though we have devices from that period, perhaps here there are not those humidity and temperature conditions mentioned in the RTB(?)
