ANYONE HERE rebuilding the fuser sleeves on mpc3003-mpc4503?
fuser ricoh mp4503 - 3003
Not something you want to try. I had a junior tech order the wrong sleeve unit once, 220Volt EU sleeve instead of a 110 Volt NA. Since he was already out for the day, I had to go install it. The 220v lamps didn't heat up fast enough so I had to swaps the lamps form the old unit with a torn belt to the new one. Disassembly was easy. Reassembly was not.Comment
after a few, you get the hang of it, the ideal would be to replace the fabric part too, but our supplier only has the film, and my boss doesn't want to buy them from China, because here in Italy there is a complicated discussion to be done by the administration to manage the invoices at the level of the Italian tax authorities, if you buy material from abroad if you are not a private individual.... I tried to convince him, but he has the head more hard than a calabrese man
however for now they work, usually we mount the original, we keep these as a second choice, for example on machines that will need to be replaced soon, or very old."loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)👍 2Comment
