I just installed a Ricoh MPC4503 for a customer who had an MPC3502 previously. Now, when they are printing one or two sided brochures on the 4503, the image is not centered and part of the image will be omitted on the left and right edges of a landscape print. The kicker is, when I try the same artwork at my office and on the customer's old 3502 the document prints perfectly. I tried matching all the margin settings in the 4503 user tools that I got from the two working machines in my office to no avail. The 4503 continues to give non centered printing. Any thoughts?
Ricoh MPC4503 Print registration
Re: Ricoh MPC4503 Print registration
I'll just go straight to something basic before people offer advice that is more complex. Is there paper definitely in the middle of the trays paper guides? What I mean is, on the 03 models sometimes they slip out of place. To check it, you take the paper out of the tray, slide the guide to the middle so it is hitting against the lift plate, the other guide should also hit the lift plate at the same time. If one hits and the other doesn't, turn the tray upside down, 1 screw in the middle of white gear, push both guides against lift plate then screw the white gear back in again. Sounds very basic like I said but have seen this happen a lot on that model machine. -
Sent from my WAS-LX1 using TapatalkComment
Have anyone performed an 'all clear' before you delivered this machine, perhaps while preparing it for a new client etc?
If so you will need to re-enter the setting from the birth certificate.
His problem is because of a factory default for duplex. They add a 5mm offset to the back side to allow room for hole punching and stapling without taking out portions of the text. First time I saw this was on an Aficio 551. Used to be a User Tools setting but they moved it to one of the functions screen setting.Comment
