Ricoh C4504 strange problem, Black screen but not always
  • BartLow
    • Jan 2017
    • 9
    I have a strange problem on one of my c4504s. When I press the “Turn on” button, the printer seems to start (it starts to make noise - the belt turns, the fused heats up, etc., but the screen does not light up (panel don't start). Also I don't see any light leds on main controller board, but the hard drive is spinning up. When I press power button again, the screen turns on, panel loading but after i see the “shutdown” message and machine turns off.
    I disconnected all connectors from the IPU expect power button, power supply, power supply control and screen, but nothing changes. All three incoming lines of 5V on IPU connector seems ok.
  • luca72
    • Oct 2017
    • 1778
    i for first thing, I would try the panel of another machine, just to discriminate between the panel and everything else, some panels that failed, it happened to me
    if you left the start panel in normal mode, you can try to update the firmware, but im not very fiducious.
    "I'll be back"
      • 37489
      Can you access WIM to see if there are any error messages displayed there? Have you tried a full power down to clear any lock circuit?
      • BartLow
        • Jan 2017
        • 9
        No, seems ethernet controller power up but I can't connect to machine
        • BartLow
          • Jan 2017
          • 9
          I think problem in IPU, perhaps the main controller is not receiving all the necessary power line. I checked 5V lines and it's ok. Where is 3.3V here?
          • BartLow
            • Jan 2017
            • 9
            Another panel don't work also in turn, the panel of this machine on another machine starts normally
            • BartLow
              • Jan 2017
              • 9
              Startup process
