Random drops of toner - Help Please - Pics attached
  • WIZARDofJOZ
    • Feb 2013
    • 28
    I have pictures showing the black spots of random size and placement only on the left (Front of copier) side of the sheets about 3" in
    I also have the pic showing the toner build up on the front side ONLY of the transfer roller. I have changed out the entire black drum unit and charge roller and wax bar.
    it seems to be dropping from somewhere on to the sheet as it passes???
    • 35209
    It could be the development unit leaking, dirty ITB or ITB cleaning unit. Any of which could be caused by not using Genuine Ricoh toner.
    • WIZARDofJOZ
      • Feb 2013
      • 28
      All I use is Genuine Ricoh Toner. I don't trust the compatible stuff. I also have really small micro spots of magenta on over the whole sheet. Can't see them without a loupe
      Transfer Cleaning unit?
        • 35209
        Could be or the ITB assembly
        Oh by the way. what is the model? Some problems can be model specific.
        • WIZARDofJOZ
          • Feb 2013
          • 28
          Ricoh Pro C5100s
          • copier tech
            • 7980
            This looks like waste toner. I'd start by removing & rebuilding the transfer cleaning unit.
            • M&T
              • Sep 2021
              • 7
              I agree, it should be the ITB cleaning group
