transfer case assembly on a mpc3501 vs a mpc2800
  • fshead
    • 2376
    HI
    I have maybe 3-5 of these older workhorses in the field scattered all over.
    I have one that needs the transfer case changed but i forget which model has the thicker transfer roller.
    As I found a modded unit I did 2-3 years ago i do not know if it is the mpc3501 or the mpc2800.
    \The only difference I remember was the thicker transfer roller.
    If one swaps the entire unit will it work in either machine?
    thanks
  • Gift
    • Mar 2011
    • 2459
    Re: transfer case assembly on a mpc3501 vs a mpc2800
    Originally posted by fshead
    HI
    thanks
    I'm sitting next to a 3mpc001 and this one has the thicker roller compared to MPC2500 (not shure what the 2800 roller looks like though^^)
    • fshead
      • 2376
      hi thanks
      I will take a pic of both rollers and post to compare.
      • fshead
        • 2376
        So I lucked out and had a service call close by that had 2 old mpc3501 pushed off to the side as the customer had them replaced with newer machines.
        the mpc3501 transfer roller is thicker than the mpc2800/3300 series.
        I was able to take the whole assembly from the machine they are no longer using.
        I still do not know if i could have used the older assembly as it seems the transfer roller is driven by contact with the transfer belt.
