Mp9002 dont permit to change/manage address book via wim
  • luca72
    • Oct 2017
    • 1778
    #16
    Have you tried to edit the address book through User Tools. I can't remember if the Address Book on that model is stored on the HDD or in NVram. If it was on the HDD, it is gone unless someone had made a backup either through WIM or SP mode. I always trained my customers to make a backup through WIM anytime there were changes.
    probably the address book is on nv-ram, because I formatted the disk and it was not deleted.
    from user tools it is possible to edit the address book, and also from wim using the guided insertion.... only the insertion/modification in manual mode from wim does not work and gives an error.
    There are no problems with backing up the address book, because we have other machines with the same address book around the company.
    "I'll be back"
    • luca72
      • Oct 2017
      • 1778
      #17
      Originally posted by Gift
      Is this the SP called like "UCS initialize all Settings / Adress Book...." you would use in factory SP in case the admin password is lost?
      In case It's not you might try this out. Otherwise I would try and Factory reset the MFP with user tools/admin settings method.
      I forgot to write this, but reset sp801 UCS, was one of the first things I tried, and it had no effect.
      "I'll be back"
      • GIUBOSS
        • 1435
        #18
        Have you checked the error/code log for the result?
          • 37490
          #19
          No, it is the one you use when you trade in a machine and need to erase the entire address book but not anything else.
          • luca72
            • Oct 2017
            • 1778
            #20
            no, that type of operation is not displayed in the configuration log, it seems like a script error (?) maybe using the browser's debug function you can see where the stumbling point is.
            I'm starting to suspect a little, since the address book was not deleted by formatting the hdd, that it is on the nv-ram, and that perhaps this is working badly...perhaps?
            "I'll be back"
            • GIUBOSS
              • 1435
              #21
              I wouldn't rule it out.
              • Gift
                • Mar 2011
                • 2459
                #22
                I'm pretty shure the MFP will ask for new credentials if you run that SP in factory mode and restart the machine^^
