Fuser Sleeve
  • Spud
    • Aug 2021
    • 5
    Fuser Sleeve
    Good Evening, Can you use a D2424042, (MP C4504) Fusing Sleeve in a MP C3504?
    Thank you
    • 37489
    Re: Fuser Sleeve
    Seeing as Ricoh only makes 2 different sleeve units, one for where the local power 110/120 volts and the other for 220/240 volts, that is the 220/240 volt model and you liver in a 220/240 volt part of the world, YES.
    • nokktekk
      • Mar 2018
      • 44
      Re: Fuser Sleeve
      Thank you
      I am not sure on the 04 series. But I do know for a fact that The MP C4503 sleeve is different from the MP C3003. I think they are different. But, you can try and let us know.
      • Gift
        • Mar 2011
        • 2459
        Re: Fuser Sleeve
        I think the sleeves for the higher speed MPCs uses a different lamp with higher wattage/more power - from my experience they work for the slower units, too but not vice versa. Haven't tested it with the 3004 series though but with it's predecessors.
        • Spud
          • Aug 2021
          • 5
          Re: Fuser Sleeve
          Yes the MP C4503 Sleeves are interchangeable.. I have have since found out that the 4504 are different to the 3504. The 4504 sleeves have fuser shields within the sleeve.
          Thanks for all your input.
          • TonerMunkeh
            Professional Moron
            • 3865
            Re: Fuser Sleeve
            The D150 sleeve has the shield too and I fit it to the 30 and the 35. May be worth trying?
            Hit it.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Re: Fuser Sleeve
              Thank you
              Yes it works
              Regards Mark
              • Pixtech Frameworks
                • May 2020
                • 238
                Re: Fuser Sleeve
                3003/6003 sleeve use the same sleeve, even 2003/2503 too. They all use same sleeve, I've tried it on several model and it works.
