mp6503 sc440-01 only A3
  • marcotris80
    • May 2012
    • 5
    [Error Code] mp6503 sc440-01 only A3
    hi,
    i have a problem with an mp6503, error sc-440-01 only print and copy on A3
  • GIUBOSS
    • 1435
    Re: mp6503 sc440-01 only A3
    Originally posted by marcotris80
    hi,
    pull down the transfer belt and do a thorough cleaning, how many pages did it produce?
    SC440-01 D Transfer output abnormal (voltage leak detected)
    When the transfer voltage was output, the feedback voltage remained
    higher than 4V for 60 ms.
    • Transfer current terminal, transfer power pack disconnected, damaged
    connector
    • Transfer power pack defective
    • Remove the transfer unit
    • Inspect the terminals at the front and rear
    • Replace transfer power pack
    • luca72
      • Oct 2017
      • 1778
      hi,
      it would be interesting to have more information, it could be the consumables to throw away, however, I would start by pulling down the transfer unit, and give it a good clean, there could be the power pack buried by the toner, then I would visually check the contacts, and the lifting handle , which is not set upside down
      "I'll be back"
      • marcotris80
        • May 2012
        • 5
        hi,
        the machine has 990000 copies and the transfer unit has already been thoroughly cleaned. But the problem is still present
        • davel
          • Oct 2011
          • 1104
          PM parts changed?
          • marcotris80
            • May 2012
            • 5
            everything except Transfer belt
              • 37489
              Has the transfer belt ever been changed? THe recommended replacement is 600K.
              • marcotris80
                • May 2012
                • 5
                has not been changed
                • DRichard
                  • May 2008
                  • 482
                  BINGO!
                  "Enjoy every sandwich."
                  -- Warren Zevon
                  • tsbservice
                    Field tech
                    • 8016
                    Wait.. you have machine with million count and won't consider changing consumable part throwing a code
                    • marcotris80
                      • May 2012
                      • 5
                      sorry, the transfer belt has been replaced to 760000 copies by the old technician who managed the machine and it was not reported in the maintenance sheet
                      • GIUBOSS
                        • 1435
                        print or copy with the front door open, blocking the switches and check the passage of the paper and whether at the moment of blocking the sheet is printed well or not.Have you tried with different tests ?????
                        • Brianneoe
                          • May 2015
                          • 318
                          Had this problem in a kitchen area that had high humidity. Set the paper type to thick and it worked..The issue turned out that the paper was too wet..BTW..I replaced the whole transfer unit with a new one and it still had the problem before I removed the wet paper
                          • luca72
                            • Oct 2017
                            • 1778
                            try to check/clean all metal HV conctact that touch the voltage point, and try to cover (for test) the HV cable and connector with inusating tape....the only way will be try to change the eintere group with one pick up from another machine, but seem of know that you havent
                            "I'll be back"
