IM C3010 ; Toner from an independent supplier
  • anothertech
    replied
    Try this,
    1. Set SP5051 to 1.
    2. Power copier off then back on.
    3. Set SP5051 to 0.
    4. Power copier off then back on.
  • Larhal
    replied
    Originally posted by HBE
    Which SP code is required for this?
    This is NOT possible to switch off.
  • HBE
    replied
    replied
    You can turn OFF the RFID detection since the RFID chip on the bottle does not read properly with cheap after market toner bottles
  • HBE
    started a topic IM C3010 ; Toner from an independent supplier
    How can I switch off this message? No original Ricoh toner is used
